Hi all,
I have found a major issue whilst running MSM. We currently run 8 sites, which isn’t a lot of sites as the MSM page states:
“This gives you total control over your content and design whether you are running two sites or twenty sites”
We are currently upgrading the sites and get the following error whilst trying to add a custom field.
MySQL Error: 1117 Too Many Columns
It turns out the column limits set by MySQL is 4096 and each time you add a custom filed in EE it adds 2x fields to the exp_weblog_data table. Whilst this might not be an issue on a single site, this is a major issue on MSM.
You can quickly run out of custom fields. We are now trying to thin out all custom fields, not good. There is no mention of this limit anywhere and if adding custom fields used rows instead of columns we wouldn’t have this issue.
Sorry for the rant, but this has dropped me right in the bobbins…
Please can someone from the EE team tell me if a) There is a way around this? or b) Will this be resolved in version 2?
Steve
