embeds don't seem to work
September 10, 2008 6:32am
  • #1 / Sep 10, 2008 6:32am
    joninnz
    if I just seperate my content into header and footer and embed those as {embed="templateGroup/header"}, the final webpage loses styles, title, and anything else that relies on weblogs or variables even if I pass the variables in the embed tag. This is not quite what I expected. It seems all you can do with the embed command is add little snippets of HTML or am I missing something.
  • #2 / Sep 10, 2008 6:39am
    kriz
    Not really. I think it should work.
    It may be that you are not defining the paths correctly. Can we see how your header looks like?
  • #3 / Sep 10, 2008 6:54am
    joninnz
    Header—————————-
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html >
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>{exp:weblog:info weblog="{my_weblog}"}{blog_title}{/exp:weblog:info}</title>
    <link rel='stylesheet' type='text/css' media='all' href='{stylesheet={this_template_group}/site_css}' />
    </head>
    <body class="home">
    <div id="header">
      <h1 id="logo">Avocado Food and Wine Festival</h1>
      <div id="menu">
        <ul>
          <li><a href="http://{path={this_template_group}/index}">Home</a></li>
          <li><a href="http://{path={this_template_group}/wineries}">Wineries</a></li>
          <li><a href="http://{path={this_template_group}/entertainment}">Entertainment</a></li>
          <li><a href="http://{path={this_template_group}/about}">About</a></li>
          <li><a href="http://{path={this_template_group}/contact}">Contact</a></li>
        </ul>
        <div class="clear"></div>
      </div>
    </div>
    <div id="tray">
      <div id="eventdetail">
      {exp:weblog:entries weblog="Homepage" limit="1"}
        {Date_and_Time}
        {Location}
        <a href="http://{Google_location}">Show me on a map</a> </div>
      {/exp:weblog:entries}
      <div id="prices">
        <ul>
      {exp:weblog:entries weblog="tickets" limit="1"}
        {exp:simple_commerce:purchase entry_id="{entry_id}" success="{this_template_group}/success" cancel="{this_template_group}/index"}
          <li>Admission:</li>
          <li class="admission">${exp:number_format number='{item_regular_price}'}</li>
          <li>Early bird:</li>
          <li class="admission"><a class="earlybird">${exp:number_format number='{item_sale_price}'}</a></li>
        {/exp:simple_commerce:purchase}
        </ul>
      </div>
      <div id="sunrise">
      {exp:weblog:entries weblog="pages" entry="{this_messageID}" limit="1"}
        <h2>{Sunrise_Message}</h2>
    <p>  {/exp:weblog:entries}<br />
        <ul id="conditions"><br />
      {exp:weblog:entries weblog="tickets" limit="1"}<br />
          {Conditions}<br />
        </ul><br />
      </div><br />
      <div class="clear"></div><br />
    </div><br />
    Template with embed tag in it—————————————-
    {embed="avofest/header" this_template_group="avofest" this_messageID="4"}
    <div id="sections">
      <div class="inner">
      {exp:weblog:entries weblog="pages" entry_id="{this_messageID}"}
        <h2>{content}</h2>
        <br />
        <br />
        <br />
      </div><br />
    </div></p>
    <p>{embed="avofest/footer"}
    at the moment the page renders with none of the embedded templates rendered properly
    I was hoping it would be much simpler
  • #4 / Sep 10, 2008 6:57am
    kriz
    Not rendered properly, as in the style sheets are not being applied or are some of the embedded pages not being displayed at all?
  • #5 / Sep 10, 2008 7:05am
    joninnz
    http://www.avofest.co.nz/index.php?/avofest/
    check out the result and roll over the links in the main menu - the embedded template seems to be rendered literally with {tags} as plain text. Saying that the weblog tags are working in the header - it’s just the variables that don’t get passed to the embedded template.
  • #6 / Sep 10, 2008 7:23am
    kriz
    By the way your style sheets are not being applied (at least, from my side)
    And I cannot see where the variable {this_template_group} is being assigned in the source code you provided earlier.
    Additionally, you can also try putting: href=”{homepage}/wineries”
  • #7 / Sep 10, 2008 10:35am
    kriz nailed it- you haven’t defined {this_template_group} so your links are looking like
    href='http://www.avofest.co.nz/index.php?css={this_template_group/site_css}' >
    Keep in mind, a dynamic global applies only to the template it’s on.  So you’ll need to define those variables at the top of each embedded template as well.  The only way to have a variable ‘pass’ to an embedded template is via the use of embed variables.
    That all make sense?  Basically- define you’re variables at the top of the included templates and you should be good to go.
