Forum path problems after removing index.php (logout doesn't work)
September 09, 2008 1:14pm
  • #1 / Sep 09, 2008 1:14pm
    Timo Häkkinen
    I’m using the exclude method to remove index.php from my site. I’ve got everything working beautifully, but now I’m trying to set up a forum and for example logout doesn’t work. Neither does changing the skin. These links point from example.com/forum/ to example.com/?ACT=... and they simply won’t work. If I manually enter example.com/index.php?ACT… it works.
    I know removing index.php is not officially supported, but logout and changing skin seems to work just fine here on EE’s site with index.php removed. Any ideas?
    My htaccess:
    RewriteEngine on
    RewriteCond $1 !^(actual|directories|themes|favicon\.ico|robots\.txt|index\.php) [NC]
    I had to make the rewrite rule “index.php?” instead of “index.php” because for some reason that wasn’t working on my site. Is that what it’s all about, possibly?
  • #2 / Sep 15, 2008 4:05pm
    Timo Häkkinen
    No one ever set up a forum with index.php removed?
    Please post your htaccess if you’ve done that and it’s not asking too much. Any ideas how to solve this one? Having a forum that people can’t use doesn’t do anything good and I’m pretty much stuck right now.
  • #3 / Nov 22, 2008 3:02am
    timkelty
    Having the same issue, any one figure this out?
    For me, logout or change theme dropdown doesn’t work. As soon as I change my htaccess and bring index.php back, it works. I’m using the exclude method from the wiki
  • #4 / Jan 22, 2009 1:33pm
    Jason Ferrell
    I was having this same issue and it turned out the problem for me was in the htaccess rewrite.
    The rewrite rule below is what I initially had:
    I removed the question mark and now logout and theme change work as they should.
