I made a subadmin group wich I want to use for admins instead of superadmins. I got all the functionality setup the way I like but the only problem I have is that the subadmins group is unable to change the password:
Although afaik they do have the ability set to do so :
Looking at the subadmin group permissions the
Can administrate members accounts: YES
under “control panel administration”
Loggin in as a subadmin, searching for the member and then going to the password change form.
I put in his new password.
Your existing password I enter my subadmin password (definitely correct)
Then I submit the change and and it tells me that password is incorrect.
When logging in as super admin it works fine, if there is a security permission missing for subadmins I certainly can’t find it???
