No related Reverse entries - Help me on this
August 26, 2008 1:44pm
Subscribe [4]
  • #1 / Aug 26, 2008 1:44pm
    SC CTSI at USC
    <h2>Price List</h2>
    <p><table><br />
        <thead><br />
            <th>Service</th><br />
            <th>USC Price</th><br />
            <th>Non USC Price</th>                        <br />
        </thead><br />
        <tbody><br />
        {reverse_related_entries weblog = "core_facilities_prices" orderby="title"}<br />
        {if no_reverse_related_entries}<br />
        No price list for this Core Facility.<br />
        {/if}<br />
        <tr class="{switch='odd|even'}"><br />
            <td>{title}</td><br />
            <td>{usc_price}</td><br />
            <td>{non_usc_price}</td><br />
        </tr><br />
        {/reverse_related_entries}                        <br />
        </tbody>                <br />
    </table>
    In the above code, I’d really like the no_reverse_related_entries to span the entire table declaration. But if I do this, that would give me multiple tables for each entry, wouldn’t it?
    How do I go about not showing the entire table when there are no related entries?
  • #2 / Aug 27, 2008 4:47pm
    grantmx
    Only if you don’t limit the amount of entries it’s params.
    Use conditional variables to check for a value, like you did above, but include the full table in-between.
  • #3 / Aug 28, 2008 1:45pm
    Sean Gates
    Wouldn’t something like this work?
    <tr><td colspan="3">No price list for this Core Facility.</td></tr>
  • #4 / Aug 30, 2008 8:04am
    cherrypj
    Yeah, the reverse_related tag will execute everything inside its block. You’ll want to keep the table header outside of it, which means that Sean’s suggestion is probably the way to go. You’ll still see the table header with the column names, but maybe that’s an OK compromise?
