Memeber registration isn't loading
August 26, 2008 11:16am
  • #1 / Aug 26, 2008 11:16am
    lmb124
    My member registration page was working at one point. I’m not sure what happen. But now when i click the join the movement link On this site.The page just goes into a continuous load and register does come up? Any advice on how to resolve this issue or why it’s it occurring? Would be greatly appreciated?
  • #2 / Aug 26, 2008 11:23am
    What build/version are you running?  And- do you recall changing anything between the time it worked and now?  And can you tell if any of the other member templates come up?  mysite.com/index.php/member/memberlist/ for example?
  • #3 / Aug 26, 2008 11:33am
    lmb124
    I have version ExpressionEngine 1.6.4 and I’ve made a lot of changes since the last time i checked.
    Ever member on the members list profiles come up and are functioning, all the other member features are working and showing except for registration.
  • #4 / Aug 26, 2008 11:43am
    Hm- ok, go to ‘Admin- Members and Groups- Membership Prefs’- do you have ‘Enable Membership Captcha’ turned on?  If so- turn it off.  Let’s see if that’s the culprit.
  • #5 / Aug 26, 2008 12:29pm
    lmb124
    Ok yes that was the culprit. THANKS!!!
    But my next question is if i wanted to have some type of spam security on the registration form how can i set that up?
  • #6 / Aug 26, 2008 12:34pm
    Yeppers- was just a check to see if it was the captcha goofing you up.  It is- so let’s fix the captcha (would also jam up anywhere else it’s used- such as comments).  Check this kblog entry- and follow the directions to turn off ‘true type font’ in ‘Admin- System Prefs- Captcha’.  Then turn it back on for registration.  Does that fix things?
