I have an application where I need to export entries from EE to Wordpress. Anyone done this before? Is there a conversion tool handy anywhere?
August 12, 2008 9:26am
Subscribe [4]#1 / Aug 12, 2008 9:26am
#2 / Aug 12, 2008 9:30am
Do you mean on a regular basis? I’d say it depends on what import format WP can handle. Creating that in EE should not be too much of a problem.
#3 / Aug 12, 2008 10:07am
No, just a one time deal—I need to export all of my data for use on another server which has Wordpress installed. Just looking for a tool which can handle this.
#4 / Aug 12, 2008 10:37am
Well, it doesn’t really change much of what I’ve said: you need to export your EE data in a format that WP can use.
#5 / Aug 12, 2008 10:42am
Which leads me to my original question - is there a tool out there that does this? Does EE allow data exports? WP does not have an import tool listed on their site anywhere that I’ve found.
#6 / Aug 12, 2008 11:05am
WP doesn’t support the MT import format?
#7 / Aug 12, 2008 11:10am
EE allows you to do anyhting with your data, including exporting it. It’s just that I don’t know what import formats WP can handle. The MT file format looks like a worhty contender, though.
#8 / Aug 16, 2008 10:53pm
I actually recently used MT format to re-enable some old archives. I basically imported them into EE from an old EE Database backup. Anyway, WP does use MT formatting as I also used that file to test out different CMS systems.
Here is a nice link right from the Wiki on how to create an MT compliant template for EE that allows you to export your articles easily. One hint though: The actualy webpage layout is weird, you have to do View—> Source and save that as thats the actual MT formatted file.
#9 / Aug 18, 2008 2:52pm
Exporting is a bit of a pain. Why not set up a custom RSS feed from EE to WP?
#10 / Aug 18, 2008 4:11pm
To be honest, I don’t see why it would be particularly painful? The template in the wiki should get you almost there, in most cases.
#11 / Aug 18, 2008 4:12pm
Using that template I linked to is just as easy as an RSS feed and accounts for all the requisite fields. All you do is save a text file and then import.
