Thanks for the prompt response.
Expression Engine 1.6.4
Build: 20080710
URL on 404:
<a href="http://cswip.ca/system/index.php?S=e1af1d94331a9d689c4ef679d5b6cf065c4b098c&C=edit&M=new_entry">http://cswip.ca/system/index.php?S=e1af1d94331a9d689c4ef679d5b6cf065c4b098c&C=edit&M=new_entry</a>
I’m not running any extensions.
So, the part about the “Direct all…” is the weirdest thing about this. If I paste in the content of the post, but I leave out the “to” in “Direct all applications and inquiries to:” it posts without a problem. If I put the “to:” in, it doesn’t post. This is in the body of the post. I’m not using any custom fields. The thing is, the content editors have been running into this problem in other posts as well. I figured out it was “to” using a process of elimination for this content, but I can’t see why that would crash the thing, and I’m assuming that whatever is causing them a 404 error on the other posts isn’t the same word. There’s something about the structure that it doesn’t like.
Thanks for the help.
