Rewrite Question/Issue..
August 01, 2008 2:20pm
  • #1 / Aug 01, 2008 2:20pm
    josephvv
    Hello,
    Everything was working fine until just recently and now all the pages go to the homepage
    IE, mydomain.com/About-Us,mydomain.com/Contact-Us goes to mydomain.com now
    I can view my pages if I manually plug in the url string..
    mydomain.com/index.php/About-Us
    Ive tried a method from a previous thread but this didnt work .. It was working before with this method :
    RewriteEngine On
    RewriteCond $1 ^({exp:query sql="SELECT group_name FROM exp_template_groups"}{group_name}|{/exp:query}P[0-9]{2,8}) [NC]
    i would run the above in the template section and it would generate the code to insert into the .htacces file
    help?
    thanks!!
    -Joseph
  • #2 / Aug 01, 2008 4:15pm
    Hi, does this article help?
    Do you’ve got a name to your site? Also, which version and build are you on? Does it work when you remove the .htaccess rewrite?
