Magie not displaying info using tags from entry
July 25, 2008 4:09pm
  • #1 / Jul 25, 2008 4:09pm
    zwenthe
    I am having the same issues as this thread
    http://ellislab.com/forums/viewthread/84583/
    I am trying to do something like this
    {exp:weblog:entries weblog="merchants" sort="desc"}
    <h1>{title}</h1>
    {description}
    {direct_link}<br>
    {exp:magpie url="{rss}" limit="10" refresh="720"}
    <ul>
    {magpie:items}
    <li><a >{title}</a>{magpie:description}</li>
    {/magpie:items}
    </ul>
    {/exp:magpie}
    {featured}
    {/exp:weblog:entries}[/quote]
    Where RSS is defined in a weblog field.
    I have hardcoded the magpie rss url into the template and it works fine… it just won’t pull the url from the entry.
  • #2 / Jul 25, 2008 4:25pm
    I think you are running into a parse order issue here. You could try embedding the magpie tag into an external subtemplate, passing the rss parameter to it:
    {embed=my_includes/magpie rss="{rss}"}
    In your embed you’d then use {embed:rss} to reference the URL.
    On second thought, plugins are meant to be nested, so this is not the issue here. Just to clarify.
  • #3 / Jul 25, 2008 4:31pm
    zwenthe
    actually I think I found it out. The auto hyperlink was enabled, and as such it would use the rss url… as soon as I disabled that it worked.
    It would be nice if it could work so I could autolink, but I can work around that
  • #4 / Jul 25, 2008 4:39pm
    Ah, that would explain what you are seeing, too, yes. So, does that solve your issue?
  • #5 / Jul 25, 2008 4:41pm
    zwenthe
    Yep I am good… Maybe a feature request for Magpie would be to parse the http so that autolink could stay enabled
  • #6 / Jul 25, 2008 4:55pm
    Thanks a lot, closing this one 😊
