Hi everyone!
Session variables are just perfect;)
There is only one more thing which gives me some trouble..
1) I have a template with weblog entries loop
2) Each entry is displayed in a styled div
3) Each div’s id is the entry {title}
4) I have an input tag with onclick event for each div
5) Onclick event is setting session variable
Simplified, it looks like:
{exp:weblog:entries weblog="my_weblog"}
<div id="{title}">{body}<input id="{title}"></div>
{/exp:weblog:entries}
Basically, I want the session variable value to be the current entry’s title.
Now, that’s the tricky bit;). If I put sth like {exp:session_variables:set name="vt_vatr" value="{title}”} in the onclick event, it’s always the title of the last entry which is stored to the variable.
What I want to have insead is ‘the current one’. If I knew how to store the id of the actual input tag (being clicked on) to the variable, I think it would be solved.
Can anyone help?
Kind regards
Luke S.
