Moderator’s note: Moved to Howto.
Hi all,
This took me some time, but this might be due to the fact that i’m not thinking in the right direction. But i’d thought i’d ask just to make sure.
I’ve build an ajax form that does some json calls using an id based on options chosen in the previous dropdown box.
Now, for example, i have to retreive all the series from a specific manufacturer.
I have a weblog manufacturers and a weblog series. The series weblog has an manufacturere relationship field called “manufacturer_serie”.
Below is the code of the series template that retreives all the series for a certain manufacturer.
<?php
function curPageURL() {
$pageURL = 'http';
if ($_SERVER["HTTPS"] == "on") {$pageURL .= "s";}
$pageURL .= "://";
if ($_SERVER["SERVER_PORT"] != "80") {
$pageURL .= $_SERVER["SERVER_NAME"].":".$_SERVER["SERVER_PORT"].$_SERVER["REQUEST_URI"];
} else {
$pageURL .= $_SERVER["SERVER_NAME"].$_SERVER["REQUEST_URI"];
return $pageURL;
$queryString = $_SERVER['QUERY_STRING'];
//echo "1: ".$queryString;
parse_str($queryString);
//echo $id;
[{optionValue:'keuze', optionDisplay: '---Choose a serie---'},
{exp:weblog:entries weblog="series"}
{related_entries id="manufacturer_serie"}
{if entry_id == "<?php echo $id; ?>"}
{/related_entries}
{optionValue:'{entry_id}', optionDisplay: '{serie_name}'},
{/related_entries}
{/exp:weblog:entries}
]Now the question is, this works, but am i doing this ok?
