related_entries not showing
July 10, 2008 7:07pm
  • #1 / Jul 10, 2008 7:07pm
    oniracom
    I’m trying to display a related entry from a weblog, however I get absolutely no output between the related_entries tag.  Reverse related entries are working fine, and both weblogs output fine by themselves.  Also, if I leave the relationship unselected, the ‘if no_related_entries’ section does not output either.
    Any help would be greatly appreciated!
    {exp:weblog:entries disable="member_data|pagination|trackbacks" entry_id="157"}
    {title}
        {related_entries id="projects_adminContact"}
           title: {title}
        {if no_related_entries}
      <h2>No Performer Information Available</h2>
    <p>   {/if}<br />
    {/related_entries}<br />
    {/exp:weblog:entries}
    Using version 1.6.4 with MSM by the way.  I have gone through the database, and checked that ALL weblogs, custom fields, and entries are associated with the correct site in the database.
  • #2 / Jul 10, 2008 8:13pm
    oniracom
    I’ve been looking through mod.weblog.php a bit.
    Around line 356 there is a conditional statement that reads:
    if (count($TMPL->related_data) > 0 AND count($this->related_entries) > 0)
                $this->parse_related_entries();
    It seems that count($this->related_entries) always returns 0.
    Still trying to figure out exactly where that is assigned.
  • #3 / Jul 10, 2008 8:28pm
    oniracom
    Never mind. It was a bad extension.
  • #4 / Jul 10, 2008 9:44pm
    Whew. So I can close the thread?
    Which bad extension?
  • #5 / Dec 01, 2008 5:25am
    bromtec
    oniracom -
    Did you figure out which extension was causing the problem…?  I’m getting the same thing.
  • #6 / Dec 01, 2008 12:23pm
    Greg Aker
    bromtec, what extensions are you using?  If you globally shut them off with the green button in Admin -> Utilities -> Extensions Manager does it work for you?
  • #7 / Dec 01, 2008 12:47pm
    bromtec
    Greg,
    Thanks for your help. I gave that a try, but still nogo.  I am on 1.6.4.  I’m going to upgrade, but I don’t see anything in the change log relating to this.
    It’s 2 sites deployed with MSM.  The sites are virtually identical, and most of the second site was created with the duplication feature during creation, although I’ve adjusted the weblogs, custom fields and any other settings I could think of to reflect the new site.  The related entries works great on the main site, but it simply won’t work on the second site, which is deployed in a subfolder underneath the main site.  Any other ideas?
    Main site is http://www.sprayfoamsouthwest.com (think you looked at this before when I was having another issue), and the second site is http://www.firestopsouthwest.com, which is located at http://www.sprayfoamsouthwest.com/firestop/
    Thanks again for your help.
    Paul
  • #8 / Dec 01, 2008 12:49pm
    Greg Aker
    Okay, can you please try the upgrade of MSM & EE so we can see if that shakes out any bugs.  If not, we’re on the same code base for troubleshooting.  Sound fair?
    -greg
  • #9 / Dec 01, 2008 10:16pm
    bromtec
    Greg,
    I updated to 1.6.6 and my MSM was already at 1.1 (does the actual build / date matter)?  I’ve still got the same problem.  Any other ideas?
  • #10 / Dec 02, 2008 1:43am
    bromtec
    Actually, now that I updated to 1.6.6, disabling the multi-relationship extension seems to fix this problem.
    I installed the Playa extension, and that seems to have corrected the issue when I have the multi relation extension enabled and in use, although I haven’t put the Playa extension to use in any way.
  • #11 / Dec 02, 2008 2:22pm
    Pascal Kriete
    Ok, so this was caused by an extension as well?
    Playa shouldn’t be doing anything when it’s not in use.  Does the problem come back if you disable Playa again?
  • #12 / Dec 02, 2008 2:32pm
    bromtec
    That is exactly what happens - the problem comes back when I disable Playa.  Re-enable, and the problem is gone.
  • #13 / Dec 02, 2008 3:31pm
    Pascal Kriete
    bromtec:
    For help with the extensions you need to go directly to their author(s).
    I do want to work out what’s going wrong with EE though.  Could you please disable all extensions again (use the big green button so you don’t lose any settings) and then tell me step-by-step how I can reproduce this error.
    Thanks, Pascal
