My Control Panel doesn’t appear to display properly, in the respect that presently it doesn’t display any statistics, it simply displays the horizontal menu Publish Edit Templates Communicate Modules My Account Admin
Current user in Green
and at the bottom
ExpressionEngine 1.6.3 - © Copyright 2003 - 2008 - EllisLab, Inc.
Script executed in 0.5494 seconds 13 SQL queries used
Build: 20080319
reviewing your docs
http://expressionengine.com/docs/cp/index.html
I should be able to display my site statistics, but having tried to change the settings
via My Account/ Customize Control Panel / Control Panel Homepage
and selected various radio buttons to display various statistics on Left and right sides of the page
press the green button Set Display Order,
the page refreshes with a dialogue box with Update and nothing appearing under the Left and Right column
when I press the update I get
MySQL ERROR:
Error Number: 1064
Description: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘WHERE member_id = ‘932’’ at line 1
Query: UPDATE `exp_member_homepage` SET WHERE member_id = ‘932’
Please could you let me know what i’m doing wrong.. thank you
Kelli
