How do I use an {embed} within an {exp:weblog:entries} tag?
June 27, 2008 10:51pm
  • #1 / Jun 27, 2008 10:51pm
    tehulong
    Is it possible to use an {embed} that has custom weblog entry tags within an {exp:weblog:entries} tag?
    When I use the embed, the embedded tags are not parsed.  For example:
    Main Template:
    {exp:weblog:entries weblog="something"}
    {embed="embedded/misc"}
    {/exp:weblog:entries}
    Embedded Template:
    {weblog_title}
    Instead of the parsed custom field weblog title showing up, the page actually displays {weblog_title}.
    Is there a way to get around this?
  • #2 / Jun 28, 2008 1:02am
    soxhead
    The embed template is going to need its own set of {exp:weblog:entries} tags.
    What you can do is pass the entry id of a given entry to the embed template so that you can embed the /misc template for each entry.
    So you’d do something like this in your “main” template:
    {embed="embedded/misc" this_post={entry_id}}
    And then in the embed template:
    {exp:weblog:entries entry_id=this_post}
    {weblog_title}
    Hope that helps.
  • #3 / Jun 28, 2008 1:41am
    AJP
    Inside the embed, it’s probably a good idea to use the dynamic=“off” parameter as well.
    Also, you need to prefix all embed parameters with “embed:” and then the variable name.
    {embed:this_post}
    <pre><code>
    EMBED
    {exp:weblog:entries weblog="name" dynamic="off" entry_id="{embed:this_post}” limit=“1”}
    {title}
  • #4 / Jun 28, 2008 3:04am
    tehulong
    Hmm, I’ve tried out the above code but it doesn’t seem to be working.  I’m getting blank stuff where the embed should be.
    Here’s my code now:
    Main Template
    {exp:weblog:entries weblog="something" category="1" limit="10" offset="1" paginate="bottom"}
    embedded/misc
    {exp:weblog:entries weblog="something" dynamic="off" entry_id="{embed:this_post}" limit="1"}
    {content}
    Am I doing something wrong?
  • #5 / Jun 28, 2008 3:24am
    tehulong
    Ah ok, I figured it out guys—the code was missing quotation marks around the variable to be passed.
    Thanks for the help!  Here’s the stuff that works:
    Main Template
    {embed="embedded/misc" this_post="{entry_id}"}
    embedded/misc
    {content}
  • #6 / Jun 28, 2008 4:00pm
    soxhead
    AJP,
    Thanks for the corrections. That will teach me to post while intoxicated.
    Actually, it won’t. But it’s a nice thought.
    lobstersan,
    Glad you got it working.
