Category custom field name conflicts?
June 24, 2008 11:06am
  • #1 / Jun 24, 2008 11:06am
    Brent Cartier
    I wondering if there’s an issue with having several category groups all containg a category custom fields that have the same name. I’m working on a bilingual (English/French) site, and for every category, I need to have the category name in French, so I use the custom field name “category_name_fr”. I do this in 4 separate category groups.
    The problem is that I can’t seem to display the french name using the weblog:categories tag, which according to the docs, I should be able to display custom fields:
    {exp:weblog:categories weblog="contacts" category_group="4"}
      <option value="{category_id}">{if lang=="en"}{category_name}{/if}{if lang=="fr"}{category_name_fr}{/if}</option>
    {/exp:weblog:categories}
    This code shows a list of provinces, but in French, it actaully creates the dropdown which I can select from, the text is blank. My hunch is that this is a naming conflict, but I’d really prefer to keep the variable names consistent so that I can loop through several category groups in my templates and always know that the field is going to be “category_name_fr”, regardless of the group or weblog. Does that make any sense?
    Thanks for your time!
  • #2 / Jun 24, 2008 11:28am
    Hm- do a quick test on a blank template
    {exp:weblog:categories weblog="contacts" category_group="4" style="linear"}
     {category_name} - french: {category_name_fr}
    Does it fail to show there as well?and- you’re using a custom category field in multiple groups with the name category_name_fr?
  • #3 / Jun 24, 2008 11:32am
    Brent Cartier
    Hi Robin,
    Thanks for the quick reply - the clean template with the code above outputs:
    Alberta - french:
    British Columbia - french:
    Manitoba - french:
    category_name_fr is still outputting nothing. I double checked for typos in the field name etc.
    Strange eh?
  • #4 / Jun 24, 2008 11:35am
    Brent Cartier
    Hi Robin - I think I found my error - one minute…
  • #5 / Jun 24, 2008 11:51am
    Brent Cartier
    Hi Robin,
    Sorry about the mix up, the weblog:categories tag seems to be working, it’s the {categories} pair that’s giving me grief:
    Here’s some sample code:
    <ul>
       {exp:weblog:entries weblog="meetings" limit="3"  }
        <li>{title}
           {categories}
                  {category_name} - {category_name_fr}
               {/categories}
    <em>{entry_date format="%l %F %j%S, %Y at %g:%i%a"}</em>
            </li>
       {/exp:weblog:entries}
    </ul>
    <hr>
    {exp:weblog:categories weblog="meetings"  }
    In the {categories} variable pair, category_name_fr is empty, but in the weblog:categories tag, it’s displayed… The meetings weblog has only one category group assigned (id:2)
  • #6 / Jun 24, 2008 12:04pm
    Hm- try clearing the cache- ‘admin-utilities’.  Might also try specifing the group id in the weblog’s category pair:
    {categories show_group="2"}
    And I don’t think this is it- because I’d expect the category tag to have issues as well- but might run this fix just to eliminate one possibility.
    If none of the above works, I’ll get you to walk me through duplicating the issue.
    Oh- what build/version are you running?
  • #7 / Jun 24, 2008 12:21pm
    Brent Cartier
    Hi Robin,
    I tried clearing the cache, and adding the show_group parameter - same result.
    I’m running the latest verion/build and haven’t updated since install:
    ExpressionEngine 1.6.3,  Build 20080421
    Should I still try that fix you mentioned?
  • #8 / Jun 24, 2008 12:29pm
    Brent Cartier
    I tried disabling all extensions - no luck.
    I did however rename the field in that one category group to category_name_fr2 and it displays perfectly. It must be a conflict of names across groups.
  • #9 / Jun 24, 2008 12:31pm
    Crud.  This rings a vague bell, but I can’t recall if it’s this exact issue.  Let me search around, see if I can find a related thread.
  • #10 / Jun 24, 2008 12:41pm
    OK- I had seen this before in this thread and the issue is under discussion with the crew regarding whether duplicate names across groups should be allowed.  I haven’t heard the final decision on that one yet.
    So for the short term- duplicate custom field groups across category groups (or w/in the same group) should be avoided as you’re likely to run into trouble with it.  Is that going to work ok for you?
  • #11 / Jun 24, 2008 12:50pm
    Brent Cartier
    Ok - I should be able to get that working using some logic in my templates. Maybe as a decision is being made, the docs could be updated to say that “category field names bust be unique within the group and across all category groups”. I’d add a note in the doc myself but I’m still only a “Grad Student” 😉
    Thanks for the help!
  • #12 / Jun 24, 2008 1:00pm
    Yep- I already bumped the crew on it to see which way to go.  Normally would have had a bug report in on it from the first occurrence- but it wasn’t clear if it’s a bug or a documentation issue.  Sorry you got caught up in the decision making process!
    And I shall go ahead and close this on out.
