Hiya,
Well I managed to break my EE installation… basically I renamed the domain to a new one, then changed all the paths to match, then tracked down all the references to the old domain in the database and changed them to match the new domain…
Before I edited the database, I could still login to the CP, although it was doing some weird things, like saying I didnt have permission to do anything..
Basically I am left with the following login page: http://andy.net.nz/cp/index.php
And this error when I try and login:
The username you submitted was not found in the databaseI’ve checked, and my standard admin account is still listed in the member table…
I ‘thought’ it would be a simple process of changing all the references to the old domain, but looks like Im gonna lose a few hours sleep over this :(
If someone can help me troubleshoot this, it would be greatly appreciated… unfortunately, because I am running MSM, all my sites are down…
This is the error I get when I try and login from one of my other sites (note: I changed the domain paths to suit in the path.php too)
Notice: unserialize() [function.unserialize]: Error at offset 400 of 3448 bytes in /var/www/vhosts/andy.net.nz/httpdocs/cp/core/core.prefs.php on line 129
Warning: array_merge() [function.array-merge]: Argument #1 is not an array in /var/www/vhosts/andy.net.nz/httpdocs/cp/core/core.prefs.php on line 129
Warning: array_merge() [function.array-merge]: Argument #2 is not an array in /var/www/vhosts/andy.net.nz/httpdocs/cp/core/core.prefs.php on line 129
Notice: unserialize() [function.unserialize]: Error at offset 571 of 1865 bytes in /var/www/vhosts/andy.net.nz/httpdocs/cp/core/core.prefs.php on line 129
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/andy.net.nz/httpdocs/cp/core/core.prefs.php:129) in /var/www/vhosts/andy.net.nz/httpdocs/cp/core/core.functions.php on line 726
ExpressionEngine v 1.6.3
