Searching Entry By State
June 06, 2008 5:49pm
  • #1 / Jun 06, 2008 5:49pm
    DisMedia
    I need to have a custom field for entries in a weblog that designates its “state” as in US territory.  One entry can have multiple states.
    How would I create a field with 50 checkboxes for the states.  Has anyone done this before?  Is there a perfered method so coding a dropdown select box would be done easily?
    Thanks for your help!
  • #2 / Jun 06, 2008 5:58pm
    Rob Allen
    The only way I can think of doing this is to use categories for the states - this would allow you to pick multiple ones
  • #3 / Jun 06, 2008 6:03pm
    I could think of a couple of ways if you only needed one state (as in, say, an address), but if you need multiple, I think categories are the best solution.
  • #4 / Jun 06, 2008 6:06pm
    DisMedia
    Thanks bluedreamer.  That would probably work in most intances.  In this case I have top level categories already assigned.
  • #5 / Jun 06, 2008 6:34pm
    DisMedia
    Ingmar.  How would you do it if it were one entry = one state?
  • #6 / Jun 06, 2008 6:37pm
    I think a custom field {state} should work, together with the weblog search= prameter, eg. Even if you are using categories for other purposes, you could still use them for states, though; you can assign an entry to many categoies, after all.
