How to Q: Making a buddy system, how to relate 2 members to each other?
June 06, 2008 10:54am
  • #1 / Jun 06, 2008 10:54am
    plank
    Hi.
    Working on a site where i have to relate 2 users to each other in a buddy system type setup.
    Wondering if anyone has any suggestions on how to set that up?
    Ideally I was hoping for a custom member profile field, which did relational field populated with the members list, but there’s only text field, textarea, and dropdown. I suppose I can just register all the users, and then make the drop down list from that, but would rather have the list populated from the members in the db.
    Another possibility is creating the buddy sets in the member groups area, but I feel like that would be a work around, rather than the right way to do it.
    just looking for suggestions, or pointers to where i should be looking for more info that might help.
    m.
  • #2 / Jun 06, 2008 1:21pm
    plank
    ok, another possibility i found is the PM address book. Seems work around ish, since I would have to type in each user screen name, and then strip out the address book modification functionality in the live site. (hvent found a way to just turn off that functionality yet in the prefs)
    still open to any other ideas.
  • #3 / Jun 10, 2008 12:53pm
    plank
    bump?
  • #4 / Jun 10, 2008 3:14pm
    There is no obvious solution without custom coding, I am afraid.
  • #5 / Jun 10, 2008 4:52pm
    AJP
    Solspace’s User Module, allows you to categorize users using Category Groups.
    If putting them in the same category is “grouping them” enough for you, that might be work checking out.
    Leevi Graham’s LG Member, allows you to select members in entries, so if you’re relating two members in the context of an entry (game = player 1, player 2, score, etc) this might work as well.
  • #6 / Jun 10, 2008 4:55pm
    For the forum module, somebody once suggested to rename and make good use of the “ignore member” feature.
  • #7 / Jun 10, 2008 4:57pm
    plank
    Thanks. I’ll check out how those modules work.
    As well as look to making use of the ignore member feature - that could work well since this is for a closed system, small community & moderated on one level, so there will be no real need to ignore anyone
    thanks for the suggestions!
    m.
