Encoding issues with imported pMachine data
June 03, 2008 11:24am
  • #1 / Jun 03, 2008 11:24am
    dfbills
    Is there a documented fix for the character encoding problems that result from the differing encodings between pmachine db structure and EE structures?
  • #2 / Jun 03, 2008 12:04pm
    Not that I know of- it’s more of a db issue.  Did you keep the encodings consistent?  latin->latin?  If so- can you link to an example page where it’s borking?
  • #3 / Jun 03, 2008 9:58pm
    dfbills
    I just followed the step by step in the CP Home ›  Admin ›  pMachine Pro Import Utility.  I *know* it’s a problem with latin->utf8.
    Quite a few � on this page:
    http://spl.dfbills.com/P30/
  • #4 / Jun 04, 2008 10:45am
    Yep- you can’t just change the encode setting- that doesn’t actually convert the existing data.  If it was latin- need to keep it latin.  Or- actuall convert the file.  Which isn’t necessarily easy.  I think Ingmar linked to a script before that did it.
    BUT- can you just keep it latin?  When I force the browser to use latin/wester, page seems to render fine.  Try it in your browser.  So basically- keep it latin, switch the header, which is now:
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    If you’re using the global to output that, then switching it in the cp will automatically switch it in the header.  And add new entries in latin- assuming you haven’t changed the db settings.
    But to go latin-utf?  You actually have to convert the data.  Looks to me like the old data are still latin.
    That make any sense?  This stuff is tricky.
  • #5 / Jun 04, 2008 11:06am
    Robin’s spot on, of course. I suspect your data was Latin-1 (nothing wrong with that), and now your website uses utf-8. That works only for characters where it’s never an issue anyway, ie 7-bit ASCII. So, to reiterate what she said: try changing utf-8 to latin-1 in your control panel—or take the plunge, convert your database and re-upload again. Your call 😊
  • #6 / Jun 05, 2008 12:44am
    dfbills
    I didn’t have time to test this evening, but are you saying that I shouldn’t bother with the script you posted previously?
  • #7 / Jun 05, 2008 10:26am
    I think it boils down to what you want to do.  Do you want/need to move to utf-8?  If so, then you’ll need to convert from the latin->utf-8, then import.
    If you don’t need/want to?  Then just leaving it latin should solve the issue.
    Not really a right/wrong per se.  Leaving it be in latin is the easy option.  But it’s not the only option.
    Make sense?
  • #8 / Jun 16, 2008 3:39pm
    dfbills
    Finally attempting this now-
    I’ve get EE set to ISO 8859-1 encoding and I’m importing from the pMachine database with a Latin-1 encoding.  But as you said, it is really all in the display settings.
    <meta http-equiv=“Content-Type” content=“text/html; charset=charset=ISO-8859-1”/>
    instead of
    <meta http-equiv=“Content-Type” content=“text/html; charset=utf-8”/>
    Seems to do the trick.
  • #9 / Jun 16, 2008 4:02pm
    Glad to hear it. Does that mean you’re all set?
  • #10 / Jun 16, 2008 5:06pm
    dfbills
    I guess.. until I need to use extended characters 😊
  • #11 / Jun 16, 2008 5:10pm
    OK, I’m closing that one out then, for now. Unless you need, say, Chinese or Russian characters, using either Latin-1 or Unicode should be fine. If anything comes up, just start a new thread. Thanks.
