Hi -
I can’t seem to find a detailed description of the structure of EE Themes. I initially figured they were just the CSS and images for a particular site design, but when I looked at the contents of site/themes, it contains .php files.
What exactly are the concepts behind themes, and do I need to use them or can I just use CSS?
As a related question, when I create a template, one of the possible selections in the Template Type dropdown is CSS Stylesheet. Why would you do this? Why not just put your CSS files in a folder at the root of your site and refer to them with an absolute URL?
Thanks.
Larry Lewis
