A question with the URLS
May 27, 2008 3:56am
  • #1 / May 27, 2008 3:56am
    Davmit
    Hi friends,
    if we have a url like
    http://mysite.com/index.php/name_1/name_2/name_3/name_4/name_5
    then we understand its the nesting of sections opening the article page name_5
    Whats the best way to get this done in EE ?
    Can we have categories in such a way?
    Davmit
  • #2 / May 27, 2008 4:06am
    I don’t follow exactly. The default URL structure of EE is
    <a href="http://example.com/index.php/group/template/entry">http://example.com/index.php/group/template/entry</a>
    “group” refers to a template goupe, “template” to, well, a template, and “entry” to a url_title, entry_id or other such info. After that, you would want to use {segment_4}, {segment_5} etc. What “sections” are you referring to, by the way?
  • #3 / May 27, 2008 4:20am
    Davmit
    Thanks, i know the structure that you told above,
    basically the url above http://mysite.com/index.php/name_1/name_2/name_3/name_4/name_5  refers to a site in asp which i have to convert to EE
    So , is there no different structure in EE for using this Type structure ?
    what i am thinking of is , whatever may be the url ,
    for ex:
    the last will be my url_title and the 2nd last would be my category.
    So even if i go back in the url
    then my url_title will be “article_4” and category would be “name_3”
    Am i going in the right direction ?
  • #4 / May 27, 2008 4:59am
    So, is there no different structure in EE for using this Type structure?
    What do you mean? You just told me you were aware of EE’s URL structure; no, there is no different structure. You really will need url_segments, I believe.
  • #5 / May 27, 2008 5:51am
    Davmit
    ok thanks, so i will go ahead with the url_segments,
    the only thing is that here i will have to make different template groups for each section (About Us , Overview,etc) of the site.
    i Just had a doubt whether we can have that done with a single template group.
    Thanks Anyways
    Davmit
  • #6 / May 27, 2008 5:56am
    Perhaps you would also like to take a look at the Pages module? It can assist you in the creation of arbitrary URLs.
  • #7 / May 27, 2008 6:03am
    Davmit
    ok , will take a look at it
