Login Problems
May 18, 2008 3:00pm
  • #1 / May 18, 2008 3:00pm
    Oxygen Solutions
    Today I installed Stuffed Tracker onto the same domain that EE is on, configured the Stuffed Tracker Cookies and then tried to log into the EE admin area, it turns out the only way I could login was by using
    $conf['admin_session_type'] = "s";
    From this I assume that the cookies conflict so I logged in added a prefix of ee to the prefix section in EE and cleared my cookies then removed the above code. It still doesn’t work, can EE run side by side with another program like Stuffed Tracker?
  • #2 / May 19, 2008 8:40am
    oxygensolutions, I don’t have any information on Stuffed Tracker. Have you tried contacting them about possible issues with cookies?
    In the mean time, you can certainly run the CP with sessions only.
  • #3 / May 19, 2008 8:44am
    Oxygen Solutions
    As long as its not a security issue and won’t effect the general running of the site I will run it like that for the time being and see what they have to say.
    When I switch the forum module on will it effect user logging as when originally running vb I didn’t encounter any problems.
    Thanks again!
  • #4 / May 19, 2008 8:52am
    It shouldn’t. But keep in mind I’ve not tested with it.
  • #5 / May 19, 2008 8:58am
    Oxygen Solutions
    Ok, I will report my findings 😊
  • #6 / May 19, 2008 10:02am
    I’ll leave this open- see what they say.  Out of curiosity- what cookies is the tracker setting?
  • #7 / May 19, 2008 10:17am
    Oxygen Solutions
    Ones to track the progress through the site (actions, sales etc)
  • #8 / May 19, 2008 1:19pm
    Hi, os - can you just confirm that this worked as expected prior to the additional software installation?  Thank you!
  • #9 / May 19, 2008 2:40pm
    Oxygen Solutions
    It worked fine, however ive just uninstalled stuffed tracker and cleared cookies and im still unable to login which is very strange.
  • #10 / May 19, 2008 5:47pm
    Clear all caches as well.
  • #11 / May 19, 2008 5:52pm
    Oxygen Solutions
    Cleared EE Cache, removed that extra bit and can now login without any problems.
    Im going to add ee before the cookie for ee and then reinstall stuffed tracker and see what happens. (Will ensure I clear cache at each stage. Will update you all tomorrow.
    Thanks again.
  • #12 / May 19, 2008 6:08pm
    Great. Just keep us updated.
