Weblog entry: remove pages URI
May 16, 2008 7:19am
  • #1 / May 16, 2008 7:19am
    nanook
    Hi all,
    I am trying to use pagination within a weblog entry as described here.
    That doesn’t work, because the pages module is getting in the way. So, I need to remove the pages URI, I reckon. It won’t leave! I cannot remove the pages URI.
    Is it me or my karma? 😉
    Another solution would be the pagination to work with the pages module. I am open to any and all suggestions.
    Thanks everybody!... Nico
  • #2 / May 16, 2008 10:35am
    Can you give a link to the page in question, or the code you’re using?
  • #3 / May 16, 2008 10:47am
    John Fuller
    FYI:  The method for removing information for a “page” is to delete the corresponding entry from the list in Modules -> Pages.
    Edit:  Pages only works for a specific URL, pagination requires changing that URL so there is no way that pagination will work without some sort of trickiness.
  • #4 / May 16, 2008 10:59am
    nanook
    Hi Sue,
    The code is identical to the code in the docs. Different weblog fields though.
    We’ve decided to pull the plug on the pages module. Pagination works now, as expected.
    Thanks!... Nico 😊
  • #5 / May 16, 2008 11:01am
    In that case, I’ll close this.
