MSM - $system_path - relative path
May 15, 2008 12:31am
  • #1 / May 15, 2008 12:31am
    StR@ng3r
    I’m trying to get MSM to wórk. I’m on a vServer running OpenSuse 10.1 with Plesk 8.4.
    My main installation’s system directory is on /srv/www/vhosts/domainA/httpdocs/system
    Domain root of the second URL where index.php and path.php are ist: /srv/www/vhosts/DomainB/httpdocs
    I have created an open basedir rule to enable scripts from within domainB’s httpdocs directory to be able to access DomainA’s system directory. So hopefully that will work.
    Now I need to specify a RELATIVE path in domainB’s path.php pointing to domainA’s system directory. However, I have no idea how this relative path has to look like?
    How do I get from /srv/www/vhosts/DomainB/httpdocs to /srv/www/vhosts/domainA/httpdocs/system?
    Again, thanks for your help.
  • #2 / May 15, 2008 10:12am
    Try it with a full path- does it work?
  • #3 / May 15, 2008 10:53am
    StR@ng3r
    nope it doesn’t.
  • #4 / May 15, 2008 11:35am
    You generally should be ok using the full path- but Plesk seems to often be tricky.  Read over this write-up re: MSM on Plesk.  Borkage almost always seem releated to open_base restrictions.  Which I know you said you tweaked, but double check per the linked thread.
    Make sense?
  • #5 / May 15, 2008 11:32pm
    StR@ng3r
    worked. thank you
  • #6 / May 16, 2008 1:26am
    That’s a relief.
