if body not empty and comments allowed (Code?)
May 08, 2008 8:45am
  • #1 / May 08, 2008 8:45am
    simsa
    Hi there,
    i like to code something like:
    if body !=”” AND comments_allowed
    i played around and tryed some conditionals to no avail, i did even try
    {if body !="" AND if_allow_comments==TRUE}
    how can i get this to work?
  • #2 / May 08, 2008 8:53am
    Why, you could simply nest them:
    {if allow_comments}
       {if body != ""}
  • #3 / May 08, 2008 9:36am
    simsa
    Thanks Ingmar.
    I did not know that you can nest conditionals so easily. My fault probably was using if_allow_comments instead of
    if allow_comments.
    However i did solve my inlined Read more link problem. I use Textile and with Textile you avoid sourrounding a paragraph with tags when inserting a whitespace at the beginning of the paragraph. Instead you can insert
    p.
    Lorem ipsum….more text
    on the html sourcecode one can use
    {if body !=""}{body}{if:else}{summary}{/if}
    {if summary !=""}<span class="read-more"><a href="http://{homepage}/{my_template_group}/artikel/{url_title}">Read more…</a></span>{/if}
    {if body !=""}{if allow_comments}<span><a href="http://{url_title_path=">Comment</a></span>{/if}{/if}
    It´s not the nicest solution though..
