Creating a GeoRSS template using custom fields?
April 25, 2008 3:17pm
  • #1 / Apr 25, 2008 3:17pm
    mattbaily
    I have been trying to create a GeoRSS template that pulls in custom fields from a weblog. I have been testing it on google maps site and so far I have been having not much luck. It throws multiple syntax error warnings.
    I know the general xml code is good because I entered some static info between the xml tags and it displayed properly. I just can’t seem to get the dymanic content in there.
    Any ideas?
    Matt
    Current code in my rss template:
    <?xml version="1.0"?>
    <rss version="2.0" xmlns:georss="http://www.georss.org/georss">
    <channel>
    {exp:rss:feed weblog="maps_test"}
    <item>
     <title>{title}</title>
     <link>{url_title}</link>
     <description>{caption}</description>
     <georss:point>{maps_longitude_field}{maps_latitude_field}</georss:point>
    </item>
    </channel>
    {/exp:rss:feed}
    </rss>
  • #2 / Apr 25, 2008 6:00pm
    mattbaily
    Well, I kind of figured it out and this seems to work (although my markers are slightly off on google’s map):
    {exp:rss:feed weblog="maps_test" rdf="off" dynamic_start="on" disable="member_data|trackbacks"}
    <channel>
    {exp:weblog:entries weblog="maps_test" limit="10" rdf="off" dynamic_start="on" disable="member_data|trackbacks"}
    <item>
     <title>{exp:xml_encode}{title}{/exp:xml_encode}</title>
     <link>http://www.test.com</link>
     <description>Test</description>
     <georss:point>{exp:xml_encode} {maps_longitude_field} {maps_latitude_field} {/exp:xml_encode}</georss:point>
    </item>
    {/exp:weblog:entries}
    </channel>
    </rss>
    {/exp:rss:feed}
    I am now trying to hook it into the Coollocation tags in the template so it displays on my map.
