Having a bit of difficulty with commenting module
April 25, 2008 2:06pm
  • #1 / Apr 25, 2008 2:06pm
    stevefink
    Hi folks!
    I’m having slight difficulty with my commenting module. It’s verified to be installed and recognized by Expression Engine. However, when I submit a test comment (while being logged in), it doesn’t show up on my Control Panel for moderation, nor in my comment template that I have setup.
    Really odd. Perhaps I’m missing something simple. Here’s my comments template:
    {exp:comment:entries weblog="foo"}
                    <div class="post_comments">
                        <h2>Comments</h2>
    <p>                    <div class="comment"><br />
                            </p><h4> {name}, on {comment_date format="%Y %m %d"} said:</h4>
    <p>                        <br />
                                {comment}<br />
                            <br />
                        </div><br />
       {/exp:comment:entries}    <br />
                            {if !no_results}              <br />
                       <hr ><br />
                            {/if}<br />
                        </p><h2>Add a Comment</h2>
    <p>                    <fieldset><br />
                            <legend>Add a Comment</legend><br />
                             {exp:comment:form}</p>
    <p>                    {if logged_out}<br />
                                <br />
                                    <label for="name">Name:</label><br />
                                    <input id="name" type="text" class="field" value="{name}" /><br />
                                <br />
                                <br />
                                    <label for="email">E-mail:</label><br />
                                    <input id="email" type="text" class="field" value="{email}" /><br />
                                 <br />
                       {/if}<br />
            <br />
                                <br />
                                    <label for="message">Comments:</label><br />
                                    <textarea id="message" rows="5" cols="50">{comment}</textarea><br />
                                <br />
                                <br />
                                <br />
                                    <button id="submit">Submit</button><br />
                <br />
                                <br />
                           {/exp:comment:form}  <br />
                        </fieldset>
    Thank you for your help all,
    /sf
    Mod Edit: Moved to the Technical Support forum.
  • #2 / Apr 27, 2008 11:16am
    Are you nesting it inside a weblog tag?  You shouldn’t be- but that {if !no_results} suggests you might be- and the syntax is off.
    Can you go ahead and paste the whole template- make sure the comment tag and form aren’t nested inside other tags- and if possible, link to an example page in action?  Also- just for testing, can you set it so non-members can comment, so the form will show?
    And lastly- what version/build are you running?
  • #3 / Apr 27, 2008 1:05pm
    stevefink
    Hi Robin and everyone,
    The problem here was my <textarea> object did not have a name=“comment” attribute. I had to add the appropriate name attribute to the name/email input fields as well. After that, the code above works like a charm. 😊
    Cheers and thank you for the reply,
    /sf
  • #4 / Apr 27, 2008 1:07pm
    And yes- that was right smack in my face and I didn’t notice it, did I?  Heh.  Glad you did.  And glad that squared things away.  (Though I’m still fuzzy on what that !no_results is up to, but if it works, it works.)
    I’ll go ahead and close this puppy out.
