Hello,
how may I completely remove the breadcrumb navigation from CP?
Many thanks in advance.
April 09, 2008 12:43pm
Subscribe [2]#1 / Apr 09, 2008 12:43pm
Hello,
#2 / Apr 10, 2008 4:52am
nobody can help?
#3 / Apr 10, 2008 4:57am
I suppose you’d have to modify your CP templates directly.
#4 / Apr 11, 2008 1:10pm
Hello Ingmar, thank you for your reply. Actually this is what I’m trying to do but I’m not able to do it nor to find the crumb navigation links… Do you have any suggestion?
#5 / Apr 11, 2008 1:16pm
I finally solved…
Modifying the following line in cp.display.php
var $crumb_ov = FALSE; // Crumb Override. Will prevent the "M" variable from getting auto-linkedwith
var $crumb_ov = TRUE; // Crumb Override. Will prevent the "M" variable from getting auto-linked... did the trick. Thanks anyway.
#6 / Apr 11, 2008 1:36pm
Actually, I didn’t mean to hack cp.display.php, but simply modifying the CP templates, but whatever works for you 😊
#7 / Apr 11, 2008 1:55pm
Hello again Ingmar… I think I need some rest… :D
where can I find the CP templates?
#8 / Apr 11, 2008 2:00pm
Hm, I must’ve been thinking of something else. Carry on. 😊
