ExpressionEngine tag in blog article
April 02, 2008 12:04am
Subscribe [4]
  • #1 / Apr 02, 2008 12:04am
    mogya
    Hi,all.
    How are you doing to write ExpressionEngine Tags in your blog entry?
    Today I wrote some sample code on my blog:
    BraBraBra….
    You can use {if} method like this:
    {if segment_2 == "category"}
    BraBraBra….
    When I published this blog article, all contents after this article disappered!
    I guess the reason is this tag is still alive…
    Then, how to KILL this tag? How to write sample ExpressionEngien tag code on my blog? Give me good idea!
  • #2 / Apr 02, 2008 12:56am
    Casey Reid
    If I follow what your asking, then one way you can include code in your blog posts is by wrapping them in an html code tag. Usually like this:
    ...code goes here…
  • #3 / Apr 02, 2008 1:00am
    Arun S.
    I’m also having a little trouble understand what exactly you mean.
    Are you closing the if statement?
    For example:
    {if segment_2 == “category"}
    Content
    If you don’t close the if statement, sometimes it will kill the rest of the page.
  • #4 / Apr 02, 2008 1:06am
    Casey Reid
    Just as a follow up, you should be able to also use:
    [ code ]
    ... code here ...
    [/ code ]
    Use no spaces in the code tag though.
  • #5 / Apr 02, 2008 1:35am
    mogya
    Yes that’s I want to know. I got working by [ code][ /code]!
    but
     seems not working.
    for example, paste this code on your blog entry.
    <blockquote>This is first line.
    <pre><code>{ if segment_2 == "category" }
    This is second line.
    On my site, I can’t see “This is second line.” and after that.
    Anyway I’m fine to using [ code][ /code]. Thank you for helping!
  • #6 / Apr 02, 2008 10:37am
    mogya
    BTW, where can I found more imformation about this [ code][ /code]?
  • #7 / Apr 02, 2008 10:44am
  • #8 / Apr 02, 2008 8:54pm
    mogya
