Derek,
Sorry… I should have mentioned… though I sort of thought the first post was building a bit of the context :lol:
What I have is an SAEF form for submitting weblog entries.
I have a Status form field that’s hidden, and contains the value “Open”
As an Admin, when I use the SAEF, everything comes through as “Open”.
As another member group with all the correct permissions, using the SAEF, everything comes through as “Closed”
I’m just using the default status groups that come pre-configured with EE, which are “Open” and “Closed”
For the heck of it, I switched the naming of the SAEF Status form field to “open” (lowercase “O”). It now works fine.
To further this, I have used this general method (using “Open” on SAEF forms) numerous times without any trouble. This is currently the only site I have on EE 1.6.3.
I hope that clarifies things 😊
