Conditionals within an {exp:weblog:entries} tag
March 09, 2008 6:16am
Subscribe [4]
  • #1 / Mar 09, 2008 6:16am
    DanaK
    I do not think this is possible, but I figure I’ll post it to the boards see what comes up. I have a {exp:weblog:entries} tag that is grabbing information from two different weblogs, “Blog” and “Events.” I have a custom date field in “Events.” Is there a way to kinda combine the default entry_date of “Blog” and this custom_date of “Events” so that I can “orderby” the entry_date if it’s an entry from “Blog” and the custom_date if it’s an entry from “Events.”  So, conceptually (obviously, this code doesn’t work), something like:
    {exp:weblog:entries weblog="weblog1|weblog2"
    {if weblog=='weblog1'} orderby="date"
    {if:elseif weblog=='weblog2'} orderby="custom_date_field"{/if}}
    post content
    {/exp:weblog:entries}
    If not, it’s not a big deal. I guess I’m more curious for future reference.
    ~dk
  • #2 / Mar 09, 2008 1:04pm
    Jared Farrish
    I’ve seen a couple of different ways to do this:
    {assign_variable:orderby="date"}
    {assign_variable:orderby="custom_date_field"}
    {exp:weblog:entries weblog="weblog1|weblog2" orderby="{orderby}"}
    post content
    Or…
    {exp:weblog:entries weblog="weblog1" orderby="date"}
    post content
    {if weblog=='weblog2'}
    {exp:weblog:entries weblog="weblog2" orderby="custom_date_field"}
    post content
    In another thread, though, it was explained that you can’t do what you posted. It’s probably a good thing, too, since it makes the template code hard to read if you have that in there.
  • #3 / Apr 23, 2009 2:01pm
    grizzlies
    Am I correct in assuming you can’t use a pipe to separate weblogs within the conditional?
    Meaning this won’t work:
    {if weblog_id=="1|2|3"}
    Instead, you should use the OR operator:
    {if weblog_id=="2" OR weblog_id=="2" OR weblog_id=="3"}
    The former isn’t working for me, but the latter is. Is this right?
  • #4 / Apr 23, 2009 3:25pm
    Yes, that’s correct.
  • #5 / Apr 23, 2009 4:19pm
    grizzlies
    Thanks Ingmar.
