I have followed the directions from this page, but cannot get it to work.
http://expressionengine.com/downloads/details/tinymce/
I am not seeing the “WSIWYG” option under the filed type drop down menu.
Any suggestions?
March 07, 2008 5:44pm
Subscribe [1]#1 / Mar 07, 2008 5:44pm
Any suggestions?
#2 / Mar 09, 2008 12:01pm
You won’t get an additional option in dropdowns. Generally, you’d set the relevant fields to textarea, formatting none.
You can tweak the tinymce settings in the extension settings- but you’ll want to take a look at the tinymce docs for that one. Here’s a thread on different settings.
But for now- I’d ignore that. Just go to the publish page- see if it’s showing up on any of your textarea fields. If not- I’d make sure my path settings are correct- and look for js errors.
#3 / Mar 10, 2008 6:00pm
I have it working now with the exception of no linking capabilities. I would like to be able to insert a link in the copy.
Any thoughts?
And thank you for all your help.
