Ampersand in path global variable adda a semi-colon
February 23, 2008 8:35am
  • #1 / Feb 23, 2008 8:35am
    Jamie Pittock
    Greetings.
    I’m doing the following in my path.php file:
    $global_vars = array(
        "inclusive_stack" => "4&5;"
    When I display the variable in my template it has a semi-colon on the end, 4&5;
    It’s got something to do with the ampersand and the global_vars array.
    Any ideas?
  • #2 / Feb 23, 2008 8:36am
    Jamie Pittock
    It’s even doing it in the code above.  Let’s try it using & amp; instead and with no code highlighting…
      “inclusive_stack” => “4&5”
  • #3 / Feb 23, 2008 9:35am
    Simon Clayson
    & #38;
  • #4 / Feb 23, 2008 9:45am
    Jamie Pittock
    Hello mate.
    Nope that wouldn’t work because I’m using the path variable as a parameter value in the weblog:entries tag -  category=”{path_variable}”
    It needs to be an ampersand rather than the HTML entity.  Just got to figure why a semi-colon is being added.
    Saturday afternoon fun!
  • #5 / Feb 23, 2008 9:50am
    Simon Clayson
    Is the semi colon the result of EE wanting to build the 5 into a character entity?
    What if you used “five” instead of “5” what happens then?
  • #6 / Feb 23, 2008 9:57am
    Jamie Pittock
    It displays 4&five;
  • #7 / Feb 23, 2008 9:59am
    Low
    I think EE thinks anything with a & is considered an html-entity, and should be closed with a semicolon. I’ll take a look-see.
  • #8 / Feb 23, 2008 10:02am
    Simon Clayson
    It’s gone beyond me I’m afraid…
  • #9 / Feb 23, 2008 10:07am
    Low
    Yup, the xss_clean() function that sanitizes all input data and keeps it safe will add the semicolon (line 614 in core.regex.php):
    * Validate standard character entities
    * Add a semicolon if missing.  We do this to enable
    * the conversion of entities to ASCII later.
    $str = preg_replace('#(&\#?[0-9a-z]+)[\x00-\x20]*;?#i', "\\1;", $str);
    Guess that in this case, you’d have to create an extension to set the variable you want.
  • #10 / Feb 23, 2008 11:02am
    Jamie Pittock
    Thanks all.
  • #11 / Feb 24, 2008 11:07am
    Yep- Lodewijk nailed it.  It’s a known issue- a result of some security measures.  Since it comes up rarely and can usually be resolved by using the entity instead, (and the fix adds a lot of extra load to the parsing engine) it’s lingered a bit.  But the crew is a aware of it and keeping an eye on it for 2.0.
