List articles from current section
February 17, 2008 1:44pm
  • #1 / Feb 17, 2008 1:44pm
    gdpfunding
    Hello,
    I have a sub navigation which is essentially just a list of articles.
    This is my code:
    <ul>
    {exp:query sql="SELECT blog_title, blog_name FROM exp_weblogs"}
    {exp:weblog:entries weblog="{blog_title}" dynamic="off"}
    <li><a href="http://{path=/bch/{url_title}}">{title}</a></li>
    {/exp:weblog:entries}
    {/exp:query}
    </ul>
    Unfortunately this lists EVERY article from EVERY section.  I would just like it to restrict the list to articles belonging to the same section as the current article.
    I hope that makes sense.
  • #2 / Feb 18, 2008 8:00am
    gdpfunding
    Sorry to nudge this but I still can’t find a solution :(
  • #3 / Feb 18, 2008 10:09am
    bnaut
    Someone recently suggested I try the related categories mode and it works fine for me, is this not what you are looking for?
  • #4 / Feb 18, 2008 1:02pm
    asozzi
    Assuming you mean: list all other articles from the categories the current article is in you can use:
    {exp:weblog:entries weblog="{embed:channel}" dynamic="off" category="{embed:current_cat}" limit="20" sort="asc" disable="trackbacks|member_data|pagination"}
       <li><a href="http://{title_permalink=class=showing">{title}</a></li>
    This actually does a lot more: since I used it in an embed:
    The weblog is passed manually but dynamically
    This is needed because dynamic=“off” needs to be set-> or you just list the current entry
    Also the current category needs to be passed—> A single article may belong to several categories, hence the single entry needs to be told which categorie(s) to list.
    Also the current article is highlighted in the list (class=showing).
    Hope this helps
    PS: if you’re ok with not listing the current article it’s easier to use the related articles mentioned above
  • #5 / Feb 18, 2008 3:53pm
    gdpfunding
    Im not using categories.  I need to show a list of articles belonging to the same weblog (section) as the the article currently being viewed.
  • #6 / Feb 18, 2008 4:15pm
    asozzi
    well then it’s even simpler, just leave out the
    category="cat"
    part.
    The key element is:
    dynamic="off"
    otherwise weblog:entries will dynamically reduce results according to the URL.
    Also, what is wrong with using related categories?
    Just set up a template and give it a try.
