div being put inside paragraph by xhtml formatted entry
February 14, 2008 1:39pm
  • #1 / Feb 14, 2008 1:39pm
    nosidam
    So I have an entry that is formatted as xhtml, and for some reason, EE is always wrapping a div inside a paragraph tag, and I thought it wasn’t supposed to do that.
    For example, my entry looks like this:
    Some text
    <div class="some-class">somesource</div>
    Some more text
    What’s rendered in the output is:
    Some text
    Some more text
    Now my first question is, am I doing something wrong?  Is there a setting somewhere that I screwed up that tells the xhtml formatter to ignore proper formatting for divs?
    Other than changing the formatting to none and coding the paragraphs myself, is there a way to fix this?
  • #2 / Feb 14, 2008 2:21pm
    I just tested this on my site, with your exact inputted text, and what gets returned is this:
    Some text
    Some more text
    So I can’t replicate this.  Can you let us know what version and build of EE you’re on, and what extensions you’re running?
  • #3 / Feb 14, 2008 2:47pm
    nosidam
    1.6.2 build 20080124
    As far as extensions, I’ve got Akismet Check (v.1.1), Tag Submit (v.2.0.7), and the following plug-ins:
    Word Limiter (v.1.0)
    Subcategories (v.Beta 2)
    HTML Stripper (v.1.0.1)
    Allow PHP (v.1.0)
    Randomizer (v.1.0)
    Magpie RSS Parser (v.1.3.4)
    PHP (v.1.0.0)
    Yearly Archives (v.1.11)
    Character Limiter (v.1.0)
    XML Encode (v.1.2)
    Allow EE Code (v.1.1)
    I’ve tested the test entry in a blank template and it’s doing the same thing.  I looked at the database and the entry has the correct formatting in the database, so it looks like it’s happening as it’s being rendered for output.
  • #4 / Feb 14, 2008 2:49pm
    Can you post a link to your test template, as well as the entire template code?
  • #5 / Feb 14, 2008 3:11pm
    nosidam
    I was hoping you wouldn’t ask for that. 😉  It’s on a non-publicly available dev server at the moment.  What I can do is post the code.  I changed it slightly to get everything to the lowest common denominator, but it’s still happening.
    Entry in entry form:
    This is just a test to see if EE puts a div in a paragraph.
    <div>This is in a div</div>
    Some more text.
    This is the test template:
    <html>
    <body>
    {exp:weblog:entries weblog="articles"}
    {content}
    {/exp:weblog:entries}
    </body>
    </html>
    This is the output.  The output is the same in IE6/7 and Firefox 2.
    <html>
    <body>
    Some more text.
    </body>
    </html>
  • #6 / Feb 14, 2008 3:16pm
    What is the formatting type for your content field set to?
  • #7 / Feb 14, 2008 3:27pm
    nosidam
    It’s definitely Xhtml.
  • #8 / Feb 14, 2008 4:04pm
    Hrm.  I did just replicate this.  I’ll have to look into this one.
  • #9 / Feb 14, 2008 4:31pm
    nosidam
    Whew!  I thought I did something to break it.  Thanks.
  • #10 / Feb 18, 2008 11:40am
    Boyink!
    Nosidam:  First I need to apologize, this issue slipped past me last week and should have been addressed sooner.  That’s my fault entirely - my apologies for that.
    This issue has been logged as a bug.  In the meantime if your content will have a number of different types of markup I’d suggest going with a field formatting of “none” or looking into one of the Markdown/Textile plug-ins.
