Dynamic Page Title based on Weblog Title with embeded Templates
January 30, 2008 2:12pm
Subscribe [0]
  • #1 / Jan 30, 2008 2:12pm
    David Boyer
    I’m having difficulty determining how to dynamically generate page titles if the html <title> tag in inside a template that is embedded in all my other templates.
    For each of my templates I embedded a header and footer template:
    {embed="site/header"}
       ....weblog content….
    {embed="site/footer"}
    The embedded template header includes all the head content including the <title> and meta tags.
    All I want need to do is pull the weblog name from the currently displayed weblog into the embedded header template. Obviously a variable here is the trick but I’m at a lost how to get it working correctly. A push in the right direction would be greatly appreciated. Thanks!
  • #2 / Jan 30, 2008 3:46pm
    mayest
    You need to pass the variable to the embedded templates. In your main template do this:
    {embed="site/header" page_title="Title of the Page"}
    and then in your header you would have:
    <title>{embed:page_title}</title>
    You can pass a number of variables. I send the page title, stylesheet info, keywords, description, and template group name to my header.
  • #3 / Jan 30, 2008 4:20pm
    David Boyer
    Got it. Works particularly well when used in conjunction with Lisa Wess’ tip from her blog post: http://ellislab.com/blog/entry/seo_entry_titles_and_title/
    Therefore this is the title tag I’m using:
    <title>
    {exp:weblog:entries weblog="{embed:pg_title}"  limit="1" disable="trackbacks|pagination|member_data|custom_fields|category_fields|categories" rdf="off"}
    {site_name}{if segment_1 == ""} - Welcome{/if} - {weblog} {if segment_3 != ""} - {title}{/if}
    {/exp:weblog:entries}
    </title>
    Where pg_title is being pulled from the single variable {weblog_short_name} in the template embedded variable.
    Thanks for the help!
