Hi, Stefan - I have moved this to technical support. This looks like it may be a security breach.
Thanks for reporting this. We take security very seriously and will do our best to work with you on figuring out what’s going on. To that, we need some additional information from you…
1. EE version and build (found at the bottom of your control panel)
2. Other scripts on your account, whether in use or not (phpBB, etc…)*
* If this is a shared hosting environment, the host can make a determination if the attack came through scripts on another account on the server, which is commonly the case with these types of hacks.
While we work through this, please check through these files:
* path.php
* config.php
* index.php
to ensure that there is no unusual code such as iFrames or Javascript includes; if you do find that code, then please back-up the file and remove said code. If you are unsure of what does or doesn’t belong in these files, do not hesitate to ask.
You may also wish to refresh your files by following the build update instructions.
Also please ensure that you report this to your host immediately as they can help identify where the attack originated from so that steps can be taken to prevent this in the future.
