I am finding it difficult to implement the ‘Highlight Author’s Comment’ using this guide from EE Wiki
http://expressionengine.com/wiki/Highlight_Author_Comments/
Is there any other easier way?
December 26, 2007 7:15am
Subscribe [3]#1 / Dec 26, 2007 7:15am
#2 / Dec 26, 2007 10:53am
#3 / Dec 28, 2007 8:58am
Michael, what if I choose not to use the ‘switch variable’ alternation of CSS? how will the code be different?
#4 / Dec 28, 2007 9:04am
Rather than
<div {If author_id=="1"}class="author_comments"{if:else}class="{switch="comment_dark|comment_light"}"{/if}>You’d remove the else part of the if statement and have:
<div{If author_id=="1"} class="author_comments"{/if}>Looking again at the code, I used this on a one-person blog where the author_id was always known. If your authors will be variable, we’ll have to dig a bit deeper.
#5 / Dec 28, 2007 9:18am
but that only display the author’s comment, how about the ‘else’ statement to display ‘the others’ non-author?
#6 / Dec 28, 2007 9:22am
All comments will be displayed. This will just apply an “author_comments” class to the authors comment.
#7 / Dec 28, 2007 9:36am
I use this:
<div id="commentEntries">
{exp:comment:entries sort="asc" limit="20"}
<div class="commentData">{count} - {url_or_email_as_author} wrote on {comment_date format="%d-%m-%y at %g:%i:%s %a"}</div>
<div {If author_id=="1"} class="author_comment"{/if}>{comment}</div>
<div class="other_comment">{comment}</div>
{/exp:comment:entries}
</div>But the page goes haywire.
#8 / Dec 28, 2007 9:46am
Try simplifying the div structure by consolidating the class assignment into one if statement:
</div>
<div{If author_id=="1"} class="author_comment"{if:else} class="other_comment"{/if}>
{comment}
</div>
</div>#9 / Dec 28, 2007 10:20am
Still not working… page returns blank.
How would I know what my author_id is?
#10 / Dec 28, 2007 10:39am
author_id is just a variable, so you can display it using
{author_id}within the comment:entries tag.
#11 / Dec 29, 2007 2:59am
how do i find out which author is associated with what id?
#12 / Dec 29, 2007 9:21am
You can either just use the author and author_id variables in your template in a test fashion, or if you go to the View Members area of the Control Panel and rollover the member name, the ID is the last part of the URL.
#13 / Jan 16, 2008 10:46pm
Hey Mike,
I was playing with this and couldn’t get your code to work.
Finally figured it out: In your example (which I cut & pasted from your blog)
<div [If author_id=="1"]class="author_comments"[if:else]class="{switch="comment_dark|comment_light"}"[/if]>The first “if” statement has a capitalized “If”. Once I changed it, it was all fine. So it should read:
<div [if author_id=="1"]class="author_comments"[if:else]class="{switch="comment_dark|comment_light"}"[/if]>By the way - how would you have different author styles for different authors? I couldn’t see anything about multiple conditionals in the EEDocs (but must admit haven’t searched the forums yet!).
For example:
<div [if author_id=="1"]class="author_comments"[if author_id=="2"]class="author_comments2"[if:else]class="{switch="comment_dark|comment_light"}"[/if]></code></pre>
Cheers!
Robert
#14 / Jan 17, 2008 1:01am
I worked it out by myself (where is the “proud smiley”?)
<div {if author_id=="1"}class="author_comments2"{/if} {if author_id=="11"}class="author_comments"{if:else}class="entry"{/if} >This seems to work beautifully at the moment ...
Also @ Mike - my apologies I also see that the code on your blog has [] brackets rather than {}, which means any copy & paste wouldn’t have worked anyhow. The capitalized “if” could catch folks out though as it is hard to see the difference in the sans-serif font, so might be worth changing that.
Robert
#15 / Jan 17, 2008 6:28am
Good catch on the capitalized if - I had had a note to change out the braces for brackets as I had published this before figuring out how to to prevent EE from parsing/rendering the example code.
I’ve updated the example - thanks!
