Hello!
I encountered an interesting issue that I need assistance with.
This was an issue from when I inherited this from a previous web designer, I wasn’t able to track this down.
When you try to do a search based on a specific data paramater (just one) from a drop down list, it goes to an Under Construction page (“Some issues with this webpage has been found, which are currently being repaired. Check back shortly!”).
When I opened up a separate browser page (tabbed) to go into the system to troubleshoot this, the original search worked!!! It was not until last Friday that I hit on the pattern. Whenever I had the system page open for troubleshooting, the search page worked. If I close (and/or log-out) the system page, the search fails with the same message.
I’m not sure what information to provide to help you troubleshoot this issue. The website is http://www.aslfilms.com. Feel free to try and search for a showtime near the end of the front page (if you click on Showtimes from the menu and then pick a state), you’ll get that dreaded under construction page.
Any help that I can get, thanks and much appreciated!
Todd
