hi
i am trying to get a portion of a html page with curl. it returns the full page with html, CSS, JS. so it takes little bit long time.
is it possible to get a particular part of the html?
December 13, 2007 1:57am
Subscribe [1]#1 / Dec 13, 2007 1:57am
hi
#2 / Dec 13, 2007 3:56am
curl will always return the entire page
you then need to break it up yourself
years ago (6 or so) I used regular expressions to break up a page and extract some data
admittedly it was basically just stripping the body tags and getting everything in between but it is possible to do
