I’m trying to install and configure MSM to work on a Joyent hosting plan. My first site, the “default site” was working and still works fine but I have issues with the 2nd site.
So first let me tell you that for any domain you add to the Joyent hosting plan, it creates a standard structure of folders, each with .ssh, logs, cgi-bin, etc. folders, running its own php.fcgi. Following the installation instructions I put the index.php and path.php files in the 2nd site’s webroot folder. I also edited the path.php adding a relative path to the system folder (in my case ../../../mydefaultsite.com/web/public/system/).
In the System Preferences/General Configuration of the admin panel I used the following settings:
URL to the root directory of your site: <a href="http://mysecondsite.com">http://mysecondsite.com</a>
URL to your Control Panel index page: <a href="http://mydefaultsite.com/system/index.php">http://mydefaultsite.com/system/index.php</a>
URL to your themes folder: <a href="http://mydefaultsite.com/themes/">http://mydefaultsite.com/themes/</a>
Theme Folder Path: /users/home/domains/mydefaultsite.com/web/public/themes/When running the admin panel I can change sites with no problem except that when I go to the Publish tab I get “You are not authorized to post weblog entries”. Also when I go the 2nd site homepage I get the default site’s content unformatted (without stylesheet information).
Any suggestions on how to setup correctly MSM will be greatly appreciated.
Lefteris
