Status problem with Member Groups
December 06, 2007 8:30am
  • #1 / Dec 06, 2007 8:30am
    kingdoz
    I have created a new member group with access to publish and edit any weblogs by any author.
    When I login as a member of this member group - I can publish and edit most of the weblogs with no problem. However there is one weblog that changes the status to ‘closed’ when I edit it - and I cannot change the status to ‘open’.
    I have checked everything I can think of and there is no difference between this weblog and all the others (which I can edit fine).
    Can someone shed some light on why this might be happening?
  • #2 / Dec 06, 2007 9:59am
    First thing to check is that a status group has been assigned to the weblog- in ‘Admin- Weblog Management- Weblog Admin’ under the ‘groups’ section.  If that’s not it, I’ll lay out a couple of other options to check.
  • #3 / Dec 07, 2007 10:09am
    kingdoz
    Thanks Robin - that’s done the trick.
    The status group was set to ‘none’ - when I changed it to ‘default status group’ it worked correctly.
