Nesting Loops - Categories / Articles...
November 21, 2007 9:54am
  • #1 / Nov 21, 2007 9:54am
    nimzie
    <ul class="submenu">
         {exp:weblog:categories weblog="{segment_2}" style="linear" }
           <li><a >{category_description}</a></li>
        {/exp:weblog:categories}
      </ul>
    Builds me a sweet menu as seen at :
    http://seejeffrun.ca/eengine/index.php/oldcreel/products/
    All of the articles in the right (main) area of the page is stored internally in categories.
    What I want to do is have a + beside Kayaks that is clickable (to expand) and then lists all of the articles in the Kayaks Section. As per the rest of my code, I am keeping this dynamic and having fun with it all now.
    Can someone please advise as to a resource or technique to make a hierarchical menu as per:
    - Category
    |___Article
    |___Article
    - Category
    |___Article
    + Category
    I’d prefer the simplest way to do this. Have seen some AJAX solutions but have never used AJAX before. If anyone has a step by step or some sample code they can offer, that would be amazing.
    Thanks for the help.
    Adam
    etc…
  • #2 / Nov 21, 2007 10:02am
    I’m going to shift this on over to ‘How to’- as the show/hide bits aren’t built into the tags.  I swear I’ve seen an ajax approach to it before- so I’ll search around and see if I can spot it.
    In the meantime, check out the category archive tag- it will get you your articles under their appropriate cats- and may prove a better approach to the problem.
    Make sense?
  • #3 / Nov 21, 2007 10:09am
    nimzie
    I tried:
    {exp:cat_expand:wrapper}
    {exp:weblog:categories weblog="{segment_2}" style="nested"}
    {exp:cat_expand:expander category="{category_id}" active-style="font-weight:bolder;"}
    <a href="{path={segment_1}/{segment_2}}">{category_description}
    {/exp:cat_expand:expander}
    {/exp:cat_expand:wrapper}
    Using the Expander plugin found at:
    http://gadgets.silenz.org/index.php/gadgets/item/3-level-expanding-category-based-menu/P6/
    for EE1.6
    It doesn’t work. It shifts my nav to the right (nesting cause it’s not top level (first problem).
    No sub items show.
    Boo :(
  • #4 / Nov 21, 2007 10:50am
    nimzie
    Make sense?
    Thanks - I sort of got it working.
    When I’m in a category page, I just want to show that cat / articles for that cat.
    {exp:weblog:category_archive weblog="{segment_2}"style="linear"}
        {categories}
        {if category_description}
        {/categories}
        {entry_titles}
            <li><a >{title}</a></li>
        {/entry_titles}
      {/exp:weblog:category_archive}
    Is bringing me everything back.
    I figure I should be able to code this:
    Note : in my Show parameter within the Category request .. I don’t know how to get an ID for the cat I’m in while I’m in the exp:weblog:category_archive tag
    {if category_request}
      {exp:weblog:category_archive weblog="{segment_2}"style="linear" show="???????"}
        {categories}
        {/categories}
        {entry_titles}
        {/entry_titles}
      {if:else}
        {categories}
        {/categories}
        {entry_titles}
        {/entry_titles}
    Am I close??
    Please advise.
