Forum Error
October 16, 2007 11:24am
Subscribe [4]
  • #1 / Oct 16, 2007 11:24am
    SweetSiren
    When I attempt to login into my forums this error appears:
    MySQL ERROR:
    Error Number: 1146
    Description: Table ‘bery7ski_hollywoodrag.exp_forum_prefs’ doesn’t exist
    Query: SELECT pref_forum_name FROM exp_forum_prefs WHERE pref_id=‘1
  • #2 / Oct 16, 2007 11:33am
    Is this a brand new forum or was it working before?  If it’s new- you’ll want to go to the control panel- and in ‘Modules’ got to the Forum module and set things up for the first time.
  • #3 / Oct 16, 2007 11:35am
    SweetSiren
    Actually Ive had it for a while, it happened during the update to the newest version.
  • #4 / Oct 16, 2007 11:38am
    Hm- any problems when you upgraded?  You visited the forum control panel after you uploaded the files- and followed all of the Forum upgrade docs?  Also- what version and build of EE are you running- should see both in the cp footer.
  • #5 / Oct 16, 2007 12:24pm
    SweetSiren
    Yes I followed that. Also, I must note that anytime I have done forum updates/ee updates I always have some issues with the forums.
    ver 2.0.0
  • #6 / Oct 16, 2007 12:30pm
    Wonder if the old files didn’t get replaced properly.  In 2.0- that table should have been dropped- and it was, hence the error message.  However- the fresh files shouldn’t be calling that table.
    What I’d do- ftp in, delete the system/modules/forum folder and upload a fresh copy of it- make sure all of the files are new.  See if that does the trick.  Only other thing I can think of would be some customization in the themes where you’re using a query to pull from the table- so fresh themes wouldn’t hurt either.  Or- a plugin/extension that calls the table?  Any of that sound likely?
  • #7 / Nov 13, 2007 4:46pm
    R.K.Foster
    I just upgraded to EE 1.6.1 and am getting a similar error:
    MySQL ERROR:
    Error Number: 1146
    Description: Table 'nefarious.exp_forum_boards' doesn't exist
    Query: SELECT f.forum_id, f.forum_name, b.board_label FROM exp_forums f, exp_forum_boards b WHERE f.forum_is_cat = 'n' AND b.board_id = f.board_id ORDER BY b.board_label asc, forum_order asc
    I’m still using an older version of the Forum 1.3.1 and accessing the forum module through the control panel shows no apparent problems.
    However, I cannot create or publish any new blog entries. That is how I discovered the problem. I clicked on “Publish”, selected the blog, and got the above error. I don’t see why there would be a call to the forum SQL from the Publish page???
    After doing the update of EE I uploaded the older lang.forum.php and lang.forum_cp.php files to the system/language/english directory.
  • #8 / Nov 13, 2007 4:55pm
    Derek Jones
    You will need to upgrade your forums to 2.0, R.K.  The Discussion Forum is integrated into the main application, so it’s important that you update simultaneously.
  • #9 / Nov 13, 2007 5:10pm
    R.K.Foster
    Okay, yes that solved the problem. Money is tight right now so I didn’t want to renew the forum license but I went ahead anyway. Thanks for keeping things affordable. 😊
  • #10 / Nov 13, 2007 5:11pm
    Derek Jones
    Excellent, glad we could help!  Incidentally, your license never expires, only the download account must be renewed annually for a minimal fee.
  • #11 / Nov 14, 2007 1:38am
    pea73
    I’m having the same problem as the people above. Getting the same error message. I don’t use the forums and don’t even have them installed. Do I have to renew my (long expired) license in order for EE to work? I’d rather not as my site just doesn’t need them. Thanks.
  • #12 / Nov 14, 2007 1:49am
    Derek Jones
    Did you ever have them installed?  This error would only occur in the Publish section if EE thinks you have the forum module installed, from a variable in your config.php folder.  Perhaps step back and give us more details.  When did you start seeing this error?
  • #13 / Nov 14, 2007 1:50am
    pea73
    Found the problem: Had Yes selected for “Display Forum Topic Submission Field” in the blog preferences. Sorry about that.
    Thanks for the help.
  • #14 / Nov 14, 2007 1:51am
    Derek Jones
    No problemo, glad you got it resolved!
