Hello, I just read your instructions, and from the demo version that we first purchased, we were used to create categories from the Publish—> BlogName—> Categories—-> Edit Categories.I read your steps from your previous post, and was able to create a category using ‘Admin- Weblog Admin- Category Management’ and click the ‘Add/Edit Categories’. But the problem happens when you try to edit a category via the ‘add/edit categories’ on the ‘Publish’ page , then the 404 page occurs.
On our dev site, we installed ei on http://dev2.execunet.com/sbm/
(This is behind a firewall and you can’t access this)
what i noticed is that when you click on ‘add/edit categories’ on the ‘Publish’ page, a function called [removed]nullo() is called, and this opens a pup up window,but i also noticed that its trying to access EI on
http://dev2.execunet.com/?S=628a0f7f1c7c4323c947cc2664dce3a18cbfaa3&C=admin&M=blog_admin&P=cat
Now since EI is not on the root of my website, but in the sbm folder, that is where i think the 404 is comming from
PS: I am using the latest Build: 20070918, and i deleted and re-uploaded a fresh copy of os system/cp folder.
Hope this helps.
DT-
