Is there a way to dynamically load a different paragraph or content piece on each page load?
Nelson
September 25, 2007 10:15pm
Subscribe [5]#1 / Sep 25, 2007 10:15pm
Nelson
#2 / Sep 25, 2007 10:28pm
Are you talking about a random quote or some such thing?
#3 / Sep 26, 2007 8:11am
Yes, like a random quote.
#4 / Sep 26, 2007 8:18am
The way I’d prefer would be using a weblog for storing the random content bits, each in its own entry.
Then just use
{exp:weblog:entries weblog="whatever" limit="1" dynamic="off" orderby="random"}
{your_field}
{/exp:weblog:entries}There are also two randomizer plugins available that could be used for things like this but the weblog-approach is probably the most flexible.
#5 / Oct 07, 2007 12:43am
{exp:weblog:entries weblog="whatever" limit="1" dynamic="off" orderby="random"} {your_field} {/exp:weblog:entries}
This is exactly what I’m looking for, as well. I used exactly the code that silenz posted here, but for some reason the page displays the same one entry always, no matter how many times I refresh the page. Any ideas offhand why that may be?
Here’s the code I’m using, verboten:
{exp:weblog:entries weblog="testimonials" dynamic="off" orderby="random" limit="1"}
<h4>“{mini_quote}”</h4>
<p>{testimonial_name}<br />
{testimonial_company}<br />
<br />
{/exp:weblog:entries}I’ve got a weblog called ‘testimonials’ that I want to randomize. Here’s the kicker: if I change any parameter—like, say, make it limit=“2”—it will display a different two, but always those two. If I change something else, it changes again but then stays static.
As best as I can figure it, it may have something to do with the cache. But as per Lisa’s suggestion, I deleted everything in the cache and made sure that its permissions are set properly and still no go.
