how can i write articles under other people's names?
September 20, 2007 12:20am
  • #1 / Sep 20, 2007 12:20am
    llorax
    i am working on a magazine layout and since i am putting up all the articles right now i wanted to know if i could author them by another person’s account.  also can there be articles authored by names that aren’t members?
  • #2 / Sep 20, 2007 12:29am
    grantmx
    Do this first.
    Then in Publish or Edit, go to the Options Tab and change the Author by using the drop down list.
    That should do it.
  • #3 / Sep 20, 2007 12:38am
    llorax
    awesome that helped but what about authors who aren’t members?  can you just write a display name you want as the article for that site?
  • #4 / Sep 20, 2007 12:42am
    grantmx
    If they are not members, then you could create a custom field drop down list with each of their names.  And then of course place the custom field single variable in your code.
    You cant use {author} though, because it will pull the member author who wrote the article.  You in this case.
    Update:
    I would use either or; Not both, because it will just get more complicated than it has to be.
  • #5 / Sep 20, 2007 1:00am
    llorax
    does it have to be a drop down menu or can there be just an additional field?  if say someone writes one article i dont want to have over the years hundreds of names in a drop down menu.
  • #6 / Sep 20, 2007 6:36am
    PXLated
    Doesn’t have to be a drop-down, it can just be a blank text input field (like any other) you enter the name into.
  • #7 / Sep 20, 2007 2:10pm
    llorax
    is there a tutorial about adding a separate field somewhere?  i’m not really sure what to search for and i’m very new to this program!
  • #8 / Sep 20, 2007 2:39pm
    Try a search in the docs for custom fields, the first result is the one you want. =)
  • #9 / Sep 20, 2007 2:41pm
    PXLated
    In the docs…Custom Fields
  • #10 / Sep 20, 2007 2:51pm
    grantmx
    Here is also a great step-by-step video on creating custom fields.
  • #11 / Sep 20, 2007 5:53pm
    llorax
    thanks those helped alot!  random thought, say a member is deleted from the site.  do the entries that they wrote disappear?
  • #12 / Sep 24, 2007 11:41pm
    llorax
    does anyone know?
  • #13 / Sep 24, 2007 11:43pm
    grantmx
    Sorry about that.
    To my knowledge, no.  I believe the author name for that entry will stay in the database until changed.
