Line Breaking
August 29, 2007 4:28pm
  • #1 / Aug 29, 2007 4:28pm
    Whenever I break two lines in a topic to start a new paragraph the formatting doesn’t show up in the post. No matter what I do I can only get the forum to break one line. Is there a fix for this?
  • #2 / Aug 29, 2007 4:35pm
    A few questions:
    * EE Version
    * EE Build
    * Link to specific page where we can see this
  • #3 / Aug 29, 2007 4:37pm
    Version: 2.0.0
    Build: 20070622 (not sure if this is the build number)
    http://www.tugboatenterprises.com/CMS/index.php/forums/
    This problem happens in all posts throughout the forum.
  • #4 / Aug 29, 2007 4:41pm
    If you switch to one of the default themes (say, the grey theme, or developer) - does it display correctly? The code looks correct, so this looks like a CSS issue.  To that end, I’m going to move this to the Design forum to get some more help for you with the specific issue.
  • #5 / Aug 29, 2007 4:50pm
    Thanks for your quick response. I have changed the theme to gray and the line breaks work correctly. What code am I looking for in the CSS file to fix this problem? Thanks again!
  • #6 / Aug 29, 2007 4:52pm
    I’d look at p tags and any other margin or padding you’re using.  It could be a bit tedious to sort out, CSS often is.  Hopefully someone more advanced with it will pop in here and see it right away =)
  • #7 / Aug 29, 2007 6:43pm
    grantmx
    Check your tag style. You have both the top and bottom margin set to 0px
    p {
        margin: 0 10px;
        line-height:1.4em;
