404 response headers?
August 27, 2007 6:35pm
  • #1 / Aug 27, 2007 6:35pm
    marlyred
    I have been checking to see if EE sends the correct 404 response headers when an incorrect or missing url is accessed.  Unfortunately it appears not.
    Are there plans to remedy this problem with a patch or a future release?
    Regards
  • #2 / Aug 27, 2007 6:38pm
    Hi, marylred - it absolutely can, see 404 and Throttling. You might also look at the require_entry parameter. =)
  • #3 / Aug 27, 2007 6:47pm
    marlyred
    Hi Lisa,
    Thanks for the quick reply.  Have these options been implemented here on ee.com?
  • #4 / Aug 27, 2007 6:52pm
    Yes, I just checked in the appropriate conditions for a 404 and they do appear to be implemented on this site. =)
  • #5 / Aug 27, 2007 7:16pm
    marlyred
    As an example:
    http://ellislab.com/forums/this-is-not-a-valid-url/
    does not return a 404 response header.
    I hope you don’t think I am being pedantic. I want to build a website with EE and I need to make sure everything works as it should before I go ahead and buy.
  • #6 / Aug 27, 2007 7:26pm
    I double checked this for you and that is not currently a feature in the forums; though it would make a good feature request for a future version. =)
  • #7 / Aug 27, 2007 7:59pm
    marlyred
    Thanks for the responses Lisa.  Unfortunately I cannot make a feature request as I am not a license holder….yet.
    I also noticed that the problem is also with the ee website as well as the forums..e.g.
    http://expressionengine.com/services/this-is-not-a-valid-url/ does not return a 404 not found, but 200 OK.
  • #8 / Aug 27, 2007 8:03pm
    Outside of the forums, the segment_2 location (where you have that test) is an extremely flexible location and therefore there is no built-in way to deliver a 404.  It can be used for the template, for the url-title, for a variety of different IDs, or for anything you want by using parameters.  There is absolutely no way for EE to know if it is a valid URI or not.
    But, you can specifically tell your templates what header to deliver, see this thread for several such examples =)
  • #9 / Aug 27, 2007 8:11pm
    Derek Jones
    No built in way, except of course Lisa’s aforementioned require_entry= parameter for the weblog entries tag.  We’ve never found this to be a major priority for our own site, so we use only the basic 404 behavior.  One certainly could make all such URLs as that return 404 pages if they desired.
